what is the best storage boxes for jamma boards
deltagray
0CR
Hi like the title says im looking for something to storage jamma boards when not in use
i has seen people say about tab lock mailing boxes but in my experience using them to hold console boards i use for parts they just get crushed
so i'm looking sturdy plastic box for them
i've have being thinking for mounting the to the wall when not in use but can't be bothered all the hole if i move
sorry if i have posted to the wrong page.
(sorry for the poor grammar or spelling)
Sbdesign
SEGA collector
1,638CR
Please explain the difference between pink dissipative and black conductive foam.
The difference between Anti static pink foam and black foam
When discussing the differences between anti-static pink foam and black foam, are you familiar with the specifics?
The differences are significant, although neither is inherently superior to the other. Your choice between the two should be based on your specific needs.
Pink Anti Static Foam & Static dissipative foam
  • Pink static dissipative polyethylene foam has a resistance of less than 1011 ohms.
  • It is antistatic and has low charging, which minimizes the generation of electrostatic charge.
  • Pink foam material provides protection from physical shock during handling, packaging, shipping, and storage of ESD sensitive devices.
  • Ideal for short term use.
  • Can be easily customized through die-cutting, laminating, and other methods
    Non-contaminating, non-corrosive, and non-sloughing
  • Pink foam is an economical option.
Anti static Pink foam
Notes on use
  • It is not recommended for long-term applications.
    After being used for approximately 6 months, the electrical properties may disappear and become insulating.
More foam details, please refer to my before articles ESD EPE Foam Pink
Black Conductive Foam & Anti Static Foam
  • Black foam with a surface resistivity of 1 x 103 to 1 x 109 ohms, and meets the requirements of ANSI/ESD STM11.11.
  • Black foam is made of low-density conductive polyethylene.
  • Both permanently conductive and anti-static types, which maintain their electrical properties over time and can be used for applications requiring permanent ESD protection.
  • Black foam provides effective protection against physical shock during handling, packaging, shipping, and storage of ESD-sensitive equipment.
  • Black foam does not discolor with age.
Anti static black foam
Notes on use
  • Better value for long term applications
  • Recommended in applications where conductive or Static Dissipative properties are required
More foam details,please refer to my before articles ESD PE Foam Black
jimmerd
20 (100%)
427CR
"Really Useful" plastic Storage Box's are quite good because they can be stacked as high as you dare .
Extremely ridged, also being transparent helps easy identification.
They are however not cheap.
For a big pcb like sega system 32, you need the 33 litre, otherwise 24.5 litre or less will work for smaller JAMMA.
https://www.amazon.co.uk/dp/B01M5GQVPV
If you are shipping stuff then "Wam Bam" super strong impact resistant storage boxes are super tough, although I'd still put them inside a box.
https://www.amazon.co.uk/gp/product/B07RS2YNCX
