I will try to explain impedance, perhaps this will help you to choose the right speakers.
Impedance is the complex form of resistance. Usually, speakers have an impdance of 4 Ohms or 8 Ohms, sometimes 16 Ohms. This is th DC resistance of the wire of the coil in the speaker. But a speaker is not a resistor, it's an inductor. And this makes it a litte more complicated. An inductor has a low resistance for DC and low frequencies, but the (complex) resistance is increasing when the frequency is increasing.
Then there are a few equation:
P = U * I
U = R * I
==> P = U² / R
(P = power, U = voltage, I = current, R = resistance)
This means, the resistance of the speaker is limiting the maximum power output of the speaker for a given operationg voltage of the amplifier. The lower the impedance of the speker, the higher the maximum possible power output. BUT: if the impdance of the speaker is lower than the output the ampifier can handle, the amplifier will be destroyed. So you can always use a speaker with a higher impedance than required, e.g. a 8 ohms speaker with an amplifier that can handle 4 ohms speaker. But you can't use a 4 ohms speaker (directly) with a 8 ohms amplifier.
Using 2 identical speakers in a parallel circuit, the resulting impedance will be half the impedance of one speaker, if you connect multiple speakers in a series circuit, the impedanceces of the speakers will be added for the resulting impedance (if this makes sense, it's another question).
Also be aware to use a magnetic shielded speaker when using a CRT monitor (or place it far away from the monitor). For use with TFT monitors, you don't have to use shielded speakers, of course.
And of course, you can't connect e.g. PC speakers with integrated amplifier to a speaker output directtly. You have to use a speaker without an amplifier or a dedicated transformer.
