What tool for this Header Plug?
Equites
Chief Sheesher®
35 (100%)
3,329CR
I need to make some interconnect cables up using these. They are the type commonly seen on Williams and Atari stuff.
What tool do I need to press the wires into there?
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
does that actually need to be crimped
looks like a push lock to me
like what you get in telecommunications and you use that push blade to push the wire in
don't peel back the sheath and lay the wire flat and push it in and the sheath will cut and make contact at the same time as it locks into the teeth silverfox07862015-05-20 23:21:39
Equites
Chief Sheesher®
35 (100%)
3,329CR
Thanks, but what tool do I need to use? I've no idea.
strykr
1,351CR
Its called an IDC I think.
I ended up just using a flat blade screwdriver on my system 2 cab, not perfect but does the job, im gonna swap them over for pitch terminal housing when I get a mo, I dont like them at all and heavier cable tugs on the connection.
strykr2015-05-20 23:29:12
