Whats That Thing?
69er
1,568CR
Most likely the ball tray trip motor from electronic pool table … motor turns the geared orange capstan which holds a cam/cranked plastic arm to trip the balls off then it’s shape works the microswitch I the centre to complete the cycle and stop the motor ? They do have other applications.
Work on >12v from a 15vdc battery and usually the gears inside strip teeth if somebody trips the ball tray forcibly by hand when the battery is a bit flat.
pubjoe
713CR
Great guesses that I hadn't thought of. I was thinking maybe pinball related.
There are little lamps mixed in attached to (what look like) microswitch holders.
69er
1,568CR
The microswitch / bulb holder goes to a standard starpoint button to begin a game
The table would have an associated credit and control pcb and a mars or micro-coinmech for multi coin entry, and so you can use £1 coin and set for 2 or 3 games per coin (40p\50p& 3 for £1) push button to release balls at start of second game
69er
1,568CR
With several bulbs attached and possibly a few of the motor units it could be off a horse racer or roulette type multi slot multi option BET NOW / DONT BET COIN SLOT OPEN AND CLOSE to prevent coins inserted when race is running ? Maybe from somebody’s seaside arcade oddments kept as spares or for adapting to a self build project ?
As said above they do have other applications with several bulbs could be Red Wins or Blue / Green/ Yellow/ White wins etc ……. It’s clearly just junk unless you can test the motor on each work and turn the capstan ? Different manufacturers at different times use whatever they were able to get supplied to their requirements?
Test the motors direct to maybe 12v dc see if they function ?
pubjoe
713CR
Thanks again.
Yeah, my main reason is to check they're not useful before dumping but I guess it'd be rude not to see if they work and offer them for free.
4,533CR
Just the wire is useful if the rest isn't, I'm always using old bits of looms to repair hacked up/Jammered dedicated cabs with stuff like that, wouldn't throw any wires away as it costs money to buy it
Microswitches are useful as are the Microswitch/bulb holders
