which power supply unit ?
runner
4CR
Thanks for the advice about the stuck edge connector, I managed to remove it thanks to the wd 40 which worked a treat, thought I would ask for some advice on power supply units before I pull the trigger on buying one. Do all voltages and amp ratings have to be the same as your old unit ? or can there be slight differences, for example on my cossy alien the amps is at 15, I have seen power supply units with near identical ratings apart from the amps were at 16 and not 15.
minwah
238CR
The amp rating can be different as long as it can supply at least what the game needs. Higher value than the original is ok, so 16A will be fine in this case.
