Williams Defender RAM?
philmurr
48 (100%)
2,378CR
Is all your existing RAM faulty?
I’d seriously recommend going with 4164 replacement and an adaptor.
The “mod” is reversible, gameplay identical but the game will be heaps more reliable.
char1ie
7CR
Not sure how much RAM is working or faulty until I get the screen working.
In the past I would have replaced all the chips with new ones though.
Charlie
bomjac
453CR
I cant remember if it was Roby, Stargate or Defender - but I used the following method IIRC to identify multiple faulty RAM chips for replacing - It could well be that its Robotron from what I can remember.
1. Switch on the machine, and watch the LEDs on the PCB board. If the board passes the RAM test, then LED 2 will light 2 times
2. If the board fails the RAM test, LED2 will blink, then the pattern of the 4 LED will show the faulty RAM.
How does this help me - you remove all of the ram and then power up the PCB. The RAM test will fail on the first chip it tries to read. You then power down & insert a RAM chip into that socket (31 IIRC) and reboot the PCB.
If that RAM chip is good, now the RAM test will fail on the next chip it tries to read (32 ??). Rinse and repeat until all RAM chips are tested.
Like I say - it was some 2 years ago, and I can not remember exactly which game it was, but maybe it will work, maybe not. Enjoy !
tb lilley
5 Star
1,686CR
Your 'method' is unusual. ....
You don't even know if your RAM is faulty and you're going to shotgun the lot.
Then you're left with a stock of spare RAM chips that may or may not be faulty.
And you're not really 'fixing' a machine if you don't know if its faulty to start with ....
Each to their own I guess. I'm sure plenty of people will be eager to continue to offer tech support and advice. Good luck.
andrewsm
485CR
Cricklewood I think sell them. Not cheap though.
On a side note. Rather than jump into RAM replacement, I would first check the -5 and +12V supplies are on the board. Fitting new ones if these are not there will ruin your handywork.
andrewsm2017-12-18 20:22:46
Judder
1,009CR
That 'TheDefenderProject' site is a very good resource BTW
One other good and conclusive way of testing the 4116 RAM is to pick up a ZX-Spectrum, then you get a nice retro gaming toy and a free 4116 RAM tester for free
Here's the details of how to do so, including a UK seller of 4116 RAM, and my Dad was super happy when I phoned him up and asked him to ship down my Spectrum from his loft as I had a use for it - added bonus!
http://www.thedefenderproject.com/testing-the-4116-memory/
HTH Alex
char1ie
7CR
OK, thanks all for all the info. Not sure I need a Spectrum, or a tester.
I found a few chips for a quid each or so and have ordered them. What is Cricklewood?
Seen the Defender Project site before. Lots of detailed info, thanks.
Charlie
