Williams Stargate Error 131
junkyardjedi
1CR
I picked up a Stargate a few weeks back and have been trouble shooting it making very little headway. Here's what I've done so far
Upgraded the RAM to 4164
Checked each ram for +5v
Reseated everything on the main board that was removable
Checked the pins on the board for continuity
Display produces rug image.
Beyond that I am really at a loss and any help would be appreciated. I do not have a logic probe yet but thats my next step. Since it seems that the RAM isnt receiving any data from what I have seen and read it seems like the 74153 IC's are problematic but I am unsure it if that is the issue. Once again any feedback or things to look at would be fantastic.
Jimmy
GadgetFreak
963CR
I had issues with my Robotron which kept reporting ram errors, I still run original rams in all my Williams at the moment.
Anyway, in the end it was the FlipFlops (74ls374) at 1H, 3H & 4H, so if you are sure the ram is not at fault then with a 131 error it could be 4H that is faulty.
I would try swapping the ram at 3K with 3R and seeing if the error changes, if it does then I would say then ram that was at 3K is faulty.
bomjac
453CR
131 if my memory is correct is the first ram chip that is checked. The chips are in 3 banks. Very possibly something in the address handling as suggested, but you could star by giving the ribbon cables a good wiggle.
junkyardjedi
1CR
I'm guess that the signal isnt making it to the RAM hence the 131 error As far as replacing individual ram chips they are all brand new and tested for 5v volts at the first pin so I dont think that is the issue
