wwf wrsetlefest sprite problems
arcadeandy
127CR
hi iam having problems with my wwf board its original not a bootleg, cant see any lifted pins on custom chips all traces are ok,not sure where to start? any help would be great thanx guys.
TheDaddy
14 (93%)
7,229CR
I have repaired a few of these Checked I check in this order :-
1) Check all voltages are correct and the board is getting enough voltage.
2) Check the roms , I would remove , Verify , Clean and refit if good.
3) Check ram (Either remove Test & socket)
I had one with similar issues - Broken image :-
Fixed
SEE BELOW FOR REPAIR NOTES.
I have another 2 or 3 of these to fix at some point,
Hope this helps.
Dave.
P.S I did have one with a bad track as well from ram if I remember correctly.
Lurch666
21 (100%)
4,505CR
From the picture of the PCB it looks like the eproms aren't socketed.
I can see what looks like a 6116 ram chip near the graphics eproms. I would try piggybacking a known good ram on it to see if it makes any difference.
arcadeandy
127CR
Fixed
My repair notes are not great and rushed as always but here are the notes :-
Hope this helps.
Dave.
thanx for reply! can you remember what fixed your sprite issue? il do some more checks thanx .
