Z80 test board
philmurr
48 (100%)
2,378CR
I had this idea some years ago but other projects always took over. Got the basics working a couple of months back but spent some time this week completing the work.
There are a load of test ROMs out there (some written by me) that test game RAM but they all involve burning individual EPROMs for each game. They also rely on displaying the results of the tests on screen, which is kind of flawed logic if the screen isn't being displayed properly (or if that part of the hardware has no video output).
This Z80 test board rolls all the test ROMs into one where you can select the game you want to test using DIP switches, hit the reset button on the test board and it runs the various tests and displays the results using 3 bi-colour LEDs. The idea is that you do a quick RAM test before removing the faulty board from the game cab or getting any other test kit out. Displaying the results using LEDs also means it can work with hardware that doesn't have video output (e.g. Scramble, Frogger, etc. sound boards).
It's been designed around games built on Galaxian-type hardware, but there's no reason why it can't be used on other unrelated hardware, it just needs the relevant test ROM code to be written. Where possible it tests work RAM, object RAM and video RAM (which correspond to the 3 LEDs). It will still try to display results on screen, and if the work RAM test fails it displays the failure address, the expected contents and the actual contents to help with troubleshooting. It will also suggest which are the faulty RAM chips (based on original boardset component locations)
The board flashes the relevant LED whilst running a test so you can see the test is running (even if the game board is displaying nothing on screen). For audio-only tests (e.g. Scramble sound) the board flashes the red LED 3 times before starting the test to show the test board is actually working.
It will then display sprites on screen (sprite RAM is generally not readable by the CPU so it's only an indication the sprite circuit is ok), and finally shows DIPs and inputs, updating in real-time. The board fits where the CPU goes (so if not already socketed will need that doing first), and it also rules out any bad ROM addressing logic as all of that is done by the test board.
Code has been written for, and has been tested on the following hardware, with more to follow. Up to 32 test ROMs can fit on the test board.
Galaxian
Moon Cresta
Scramble main board
Scramble sound board (works for all similar hardware with 2 AY chips)
Super Cobra main board (works for all games with the same memory map as Super Cobra)
Frogger main board
Frogger sound board (works for all similar hardware with 1 AY chip)
Mr Do! (tests work RAM, plus separately tests background and foreground RAM)
Pacman
Pictures show the test board installed on Galaxian with 3 green LEDs lit (all ok), then the board installed on Galaxian with the LED for video RAM test red showing failure
There are then pictures of the 3 tests displayed on screen followed by a programme RAM failure showing fail address and RAM contents.
Z80 Test installed all ok.jpg Test board vid RAM stuffed.jpg Testing programme RAM.jpg Obj RAM ok.jpg Testing vid RAM.jpg Prog RAM stuffed.jpg
  • Z80 test board.pdf
philmurr
48 (100%)
2,378CR
Test board code has been updated to include Pengo, Ladybug and Snap Jack
If you split the code into the correct 2K chunk for the board you want to test, it can also be burned to an EPROM and used as a standalone test EPROM without the test board
