Problem HOW? Sega model 2 -> vga? (Projector)
Sbdesign
SEGA collector
1,671CR
I’m looking to put projector in my sega rally dx.
When I did this on sr2 dx I used the 15pin from model 3 to vga on the multi sync projector and works.
Model 2 doesn’t have this output.
I can use the rgb cable straight from filter board or the bcn RGBS cables.
I was looking at the ossc
Amazon ossc
but unsure how I would connect into it, or if a cheaper better option….
Thanks
david656
218CR
Depending on the projector - if a NEC short throw for example, you'll find the VGA socket also does RGB (in the menus) I made a SCART to VGA passive adapter for mine which worked fine for 15khz stuff like PS1/PS2 etc etc but @John Bennett tested it with 24khz and that also works and is in range. so you might be able to do it natively depending on projector with a passive adapter
5,003CR
Yeah, I didn't use any of that scaler stuff, just wired it into the VGA 15-way D-SUB port - any decent projector will do 24kHz and also accept a composite sync on the HSYNC pin.
It's around 266s on here where I connected up a System24 PCB (same res as Model 2).
Oh and I'm trying to tell everyone, you want brighter than the UM280 in that video ideally - the UM361x is 30% brighter at 3600 lumens (I might flog on that projector if anyone wants something to mess with).
Sbdesign
SEGA collector
1,671CR
It’s a nec multisync I have
I have ordered some d-sub connectors
So from what you guys have said:
I’ll attach this to the rgbs cables that come out of the model 2.
The same projector works fine from the d-sub out of sega model 3 which I believe to be same resolution, unless that connector on model 3 does something different such as amplify the signal.
I am sure I have tried this with model 2 already,
It was at the start of lockdown, and I think my result was that the height was squished with black bars.
I guess I should wire to this diagram I found:
Copy the rgb?
Sbdesign
SEGA collector
1,671CR
I revived a old thread because I ended up with a issue I had a model 2 4-5 years ago.
The issue was that all the colours were extremely bright.
But as jb said: I added pots inline to each of the r g b cables.
Typically during going back and forth with this the ffb stopped working!!
5,003CR
I'd imagine that's because it's the same effect as wiring a JAMMA board straight into a TV
Model2 puts out 'TTL' level RGB, so up to 5V, and only expects an approx 1kohm load from the monitor.
VGA is 0.7V levels and a 75ohm load.
I had an op-amp circuit on mine so I didn't have any issues (which would be extreme brightness and excessive currents).
If it's displaying a steady image, but a funny shape, then I think it's just the projector being confused with the resolution and needing adjusting.
That SR2 does look lovely.
edit: just seen the resurrected thread, hopefully I've just repeated myself :D
Sbdesign
SEGA collector
1,671CR
Haha,
well at the time I didn’t know what I was doing enough to jump at it.
but sorting some projects out finally.
i googled the issue earlier and this post sounded identical in my search.
suprise suprise, it was my post!
I was thinking it was a voltage issue, and this thread must be how I know that
anyhow I got lucky because in my solder storage box I had some mini volume pots from a earlier fix on a board. (Nothing else useful in the box so this is the best fluke I’ve had when needing a part to progress)
No idea the value, but on min it’s dark but visible and on max bright but visible, so they are ideal.
I also worked out how to adjust the aspect ratio, I forgot what the setting is called, but it was on 766, and i changed it much lower, maybe scan rate or something, I’ll confirm tomorrow. The screen would shrink in width making it 4:3, will have to physically measure it to adjust perfectly.
this was it before the width adjust..
7,361CR
Haha,
View attachment 16205View attachment 16206
It looks great 👍 good impov fix
Hoping to have a working driving cab this year .. that’s my goal
