Output for streaming
88CR
Hey guys...
Does anyone have or know where I can get and adapter to be able to stream from arcade PCBs. I'd like to be able to play on an actual cab but have a line out to an upscaler, or even better and HDMI for the capture card. The only thing I've managed to find is this, but it's out of stock. https://birdlandarca.de/products/splitfire?variant=36978386403478
A friend of mine said he could design me a PCB so we could make our own, but it hasn't come to fruition yet and I want to try and get something set up soon.
Cheers, Andrew
1,791CR
On the VGA connector you put an upscaler and you should be ready to go.
There was a german DIY kit for an vido-graber PC card and somone made a mod for it so one can capture arcade games in the native resolution. I hope that I can find the link....
88CR
Yeah that one is out of stock though.
Let me know if you do find anything. Thanks
88CR
Unless I'm mistaken, that is essentially just a capture card though isn't it? This doesn't get round the issue of splitting and amplifying the video signal from a cab so that I can run the CRT and take a second signal to my PC.
1,791CR
I missunderatood your problem.
There is an aparent good solution. It says that the valtage on the input is the same on all outputs. Quite expensive. I never tried it.
88CR
Pinge
363CR
I have a couple of Betsu Betsu Jamma extractors that I use when I stream. Works very good, for scaling I use an OSSC and a GBSC.
For a couple cabinets I use Mr Video Jamma extractor but that is svideo and composite.
I feed the scalers to a cheap Hdmi switcher (4in 1out) and then a USB hdmi capture thingy.
Theese will soon be in stock, it is a friends webshop, I just have one of the prototypes of this reworked version.
Feel free to drop me a DM if you have any questions, but I am not expert when it comes to techy stuff or the English language :D
88CR
Just ordered one.. thanks!
