Yes, any K7000. Just make sure you get one with the correct neck board for your crt. They did them in standard neck size (29mm diameter) with a 10 pin neck socket and also what's called minineck size (24mm diameter) with a smaller 8 pin neck socket. The K7201 should work also, as gunblade says it's a full range AC version so it shouldn't need the isolation tranformer.
