burning 27C1000
virtvic
The Cabaret King
21 (96%)
1,977CR
I have these ST 27C1000 eproms and I know I need to swap pins 2 and 24 to burn them usinfg settings for a regular 27c010, but it's still not working.
I have double checked my knocked together adapter and pins 2 & 24 are properly swapped to each other?
Ace`
PlanB contributor #1
38 (100%)
3,826CR
Some eproms are burnt in different ways with different timings, voltages etc so you can't always just pick a generic eprom and it'll work. That's why most software lists every version and it's best to select the exact one you have, I am guessing that's not an option though if your programmer doesn't support the non-jdec version.
virtvic
The Cabaret King
21 (96%)
1,977CR
I miraculously found a windows 10 driver for my G540 burner and that supports 27C1000. I just burned one successfully. I’ll report back when it’s in a famicom cart to see if it works or not.
