Cabin Games Room Conversion
2,257CR
Looking good
bbz149
26 (100%)
1,608CR
Cheers Guy's cant wait to get the Machines in now
especially as its getting so bloody cold now
Air-Con Heater installed, Got a Friend of a Friend who is an Ain-Con Engineer to shorten and connect Pipes as this system needed the Air evacuating before use and £70 well spent! I shall start to move cabs over at the Weekend Hopefully and setting it to the lowest 16% heat on Dehumidify.
northwest
119CR
Hi. Is this heater/dehumidifier/air con unit in one ? Do they have to run 24/7 to keep humidity out or do you only run when you in ,much high running costs ? Will be starting my build after Easter and never though of this . I was going to just use oil filled electric rad with some of those caravan dehumidifier tubs
Nintendo Arcade
AL’s Arcade
750CR
Great work, That's going to be a fantastic space for you machines.
Kingspan is the key for keeping it cool in the summer and warm in the winter.
Top job
bbz149
26 (100%)
1,608CR
Hi, Yes it does all 3
Good point about the Dehumidify! I am not sure if it runs at a constant temp or if I can set it to 16 deg on Dehumidify and it will stop once the Room hits 16deg or whatever Temp I set it too. Currently I run it permanently at 16 Deg heat, and it comes on approx ever 1.5hrs for 5 - 10 min
bbz149
26 (100%)
1,608CR
Cheers Alex
I need to install a Mains Socket for the AC, hence the long wire at the rear of the Cabs. Started to move Machine in, Still need to move the Star Wars and the others at some point. Still converting the Moon Patrol Marquee Lamp to 50hz
bbz1492016-01-24 12:27:36
niknak
Raffles the gentleman thug
172CR
Looking fantastic T. nothing like the warm glow of phosphor to set a new room up just right. Think i'll have to have a chat with you about where you got the aircon from at some point if thats okay?
4,058CR
bbz149 said:
Woah! I need one of these!! Either that or there is something seriously wrong with the insulation in my build (which looks exactly the same as how you have done it).
I have an oil filled radiator on a thermostat and timer. I had to stop using the building as an office because it would double the electric bills when I switched the heater on
Do you have any info / links to what it is and where it can be bought?
Thanks.
big10p
Coins detected in pocket!
6,042CR
Thanks.
I use an oil filled radiator, too. Flipping thing pulls about 8 amps, when it's on.
