Daytona USA Special
Outrun2
Colonel Outrun
1,176CR
Cracking project this, great to see it running. Weren't all of these made in Japan for special orders?
Congrats on your efforts so far
FinalFight
73 (97%)
770CR
J69 said:
stegrey said:
brilliant so good to see it actually moving ! :)
Cool isn't it.
£40 for a 2nd hand compressor, £3 for 2 hose connectors from screwix and a couple of changes in the menu settings and it was good to go!
I wish you had kept the other one now so I could compare the 2 games
thats boss .. i know yeah
suppose its better though having the spares for that one incase you ever need them
J69
281CR
Ordyne said:
I forgot to ask, do you have a pressure regulator and have it set to the correct pressure ?
Yeah the compressor has a regulator. It's set to 5 bar as the manual advises. Interestingly the yellow car in this video has the same issue. You can see it as the car passes the slot reels
https://youtu.be/9MbqmvjX5I0J692019-08-20 10:19:49
J69
281CR
Ordyne said:
You don't seem to be getting the gear change jumps but its hard to tell from a side view.
 https://youtu.be/ndrDZ49kPRA
If that's the case Id still say there's no rapid air release working.
I need to take a better video. It definitely bumps when you change gear. Like I say, BD motor test works fine, seat moves fine in all directions during the game. There's just this strange issue where at certain points of the course there's a clicking and little shudder in the seat. It's hard to even establish what is clicking as everything moves so loudly and quickly.
5,390CR
Seem to think Rail Chase makes a loud ish click when the seat starts to move or if you press the Emergency Stop
The best way to try and find where it's coming from is put a long screw driver if you have one on each bit of the valves and your ear on the handle end, got to be from the control valve unit I would of thought, as it's all that could make a noise, that or the Pistons
Craig's Video you can just here the Air Released noises but not Clicking like that
The Rail Chase 2 I had, sure that made some clicking noises, it did have some problems with it, it wouldn't fill the tank when first switched on, had to put finger over a pipe then something would engage and would be fine, but it sometimes used to cut out also and I'd have to switch it off and back on, this video makes same noise when he gets off it but my RC Video can't hear any noises like that
Have you got Regulator on the compressor? if so what if you turn it down a bit?
https://youtu.be/8OtL3lZq9gg?t=177
J69
281CR
I've just realised Craig posted a video in his post
Thanks Craig, that's useful
The regulator is set to 5bar, which is what's advised in the manual. I suppose I could drop it to 4 and see what difference it makes. Not much I suspect though, as the yellow cab in the video I posted is having the same issue, yet all cabs in the line up will be running at the same pressure off the same compressor in tandem
I'm off Saturday and child free so I can swap out the pistons and do some trial and error testing.
Craig, would dip settings make any difference in the menu or on the drive board?
J69
281CR
I've read the manual cover to cover. Under the seat there are 2 solenoid controlled air valves. I suspect the clicking is the solenoids misfiring which is causing the seat to jump.
You can see them in this picture with one of them removed
I'll double check on my next day off that this is the issue. If so, any ideas what would cause misfiring solenoids? Especially at the same point in the track on every lap?
J69
281CR
So after closer inspection, it's always the left cylinder that is misfiring.
If you check the picture in my post above, the air comes into the cab, under a set of relays which lead into a L and R solenoid operated air valve. The air valves then lead into the cylinders. I'm fairly sure the left side solenoid is misfiring which is causing the clicking noise and the cylinder to jump.
The odd thing is the misfiring is at the exact same point of the track on every lap. That can't be a coincidence so something is telling the solenoid to fire at that point. The right side solenoid and cylinder is fine.
Any ideas? Video below
[Daytona IssueJ692019-08-22 17:25:25
acidburn
131CR
J69 said:
No it's not massively loud. You can see it at the 1min mark in the video. The car doesn't touch anything on screen but the pistons click and move slightly. I need a visit to that arcade in Rhyl to compare!
The ones in Rhyl are not the moving type.
5,308CR
Maybe it's already been mentioned, but I think there's 4 pistons there.
Each side looks like it's split into an upper piston and a lower piston.
When viewed from the rear, the top left piston (or it's solenoid) might be playing up.
Lower pistons generally do the seat banking and the upper pistons look like they're for bumps, gear changes and little (pre-programmed) jolts.
A thought anyway.
John Bennett2019-08-23 08:29:04
J69
281CR
Sorry for boring the pants off people with this thread!
I've calibrated the valves on both cylinders. The solenoid/quick breath is still clicking but it no longer causes the seat to jump which is progress. I suspect the clicking may be normal, but the pressure was too high in the left cylinder causing it to pop/jump
