Guys so let me get this straight. Using the sega io (one with extra buttons on jamma harness)
Will i be able to run a taito x2 without extra kick harness or any extra wiring?
If we are talkling about the 838-13683-93 (I dont know if all sega jvs I/o's are the same pinout, that page I put the link to goes over each one I think) yes but only up to button 5 on the jamma edge, button 6 is on another connector on the I/O so that still needs to be wired up sep to work. Theres a jumper on the i/o that sets it that way, info on that page again. I think the jamma edge on the i/o is completly standard jamma pinout,
I know i need a sound amp bit thats ok. Also will the sega io output to 15 khz ?
The I/o does not change the video signal in anyway so its down to the system your plugging ins output options, X2 for example is only 31khz or 720p, theres no 15khz mode...Naomi has a dip switch for a 15khz mode or 31khz....
I only use the i/o as a key encoder for the system, I usually plug the VGA from the system straight into my monitors VGA port....Ive never even tested the video passthrough the I/o in fact, so I cant say if it even works well...
So that means i can also use it on my tv with supergun right?
As above, no for x2, maybe yes for naomi on 15khz if the i/o passes through the signal as Id expect but never tested....
steling12019-05-02 20:14:04
