Problem Monitor Chassis / Board Started Crackling and Sparking
tb2000
3,221CR
Yes, any K7000. Just make sure you get one with the correct neck board for your crt. They did them in standard neck size (29mm diameter) with a 10 pin neck socket and also what's called minineck size (24mm diameter) with a smaller 8 pin neck socket. The K7201 should work also, as gunblade says it's a full range AC version so it shouldn't need the isolation tranformer.
eliotcole
739CR
B-e-ay-eutiful, cheers! 🫰
Yes, any K7000.
Is there a chance I can reuse the current neckboard?
