Mtc9000 ? I think ..
8,258CR
polarity don't matter on those caps
the reason I dummy load at the HOT collector first is to see if there are any shorts in deflection circuit, all you did was prove b+ is ok
i would not be too confident in that flyback either as i know where its from
Do you have an eht probe so you can see if you get initial HT and what level it is?
So C36 low or open circuit ..
Guess I’m gonna need a new one of these .
M K L
1,154CR
When that cap fails, it causes the HV to spike and the x-ray protection quickly shuts off the H drive pulse from the TDA2595. But we have seen this early version doesn't have the protection circuit so I'm wondering what is shutting it down...
8,258CR
I
I think you have found the culprit.
if i can find a replacement I can test with a known good 4n7 1500
8,258CR
Good work , 👍
Can a replacement cap be recommended pls , don’t want to get the wrong value part .. I’m having fun looking all the same ..
but just realized I was seeing 300v as 3000v !
8,258CR
D
A 4n7 1.5kv or 2kv will be fine (or 3n9) as you mentioned above. I was just pointing out what the values were. :)
Thanks 👍I will try to get my head around
The math on that .. impressive .
how it is that you can write .. from one millionth to one billionth in so few zeros ! 🤣..Thanks 👍..
is that ten to the power of minus three ?
And for that replaemt cap 4n7 1500. High pulse polypropylene ? Mkp or fkp
