mtc9000 resistor getting red hot
jengineer
47 (100%)
1,169CR
I have a Hanty 9000, it came to me with a blown fuse, replaced the fuse, chassis is dead and the ceramic resistor got super hot so I turned it off
its the one with the yellow arrow pointing to it
it's even got James Cagney stumped
RSwanson
205CR
That's R81, it's wired in series with the LOPT primary. I'd guess the LOPT is shorted (or something putting a very large load on it).
Does the largest OCP resistor on the side get VERY hot too?
jengineer
47 (100%)
1,169CR
from memory no, I don't think it did
also forgot to say there was a diode that had been totally de-soldered? so I re-soldered it,
jengineer2016-07-24 09:06:06
5,636CR
Not sure why that would have been de-soldered. I think ZD1 carries the voltage to power IC2, or something. If R81 is getting hot, it may be worth checking high voltage cap C36, which I think is in circuit with it. I've had a couple of C36 caps go. If it has gone, check the HOT too, as I think it can cause that to pop.
RSwanson
205CR
Strange, I can't see why that would be missing. It protects IC2 from overvoltage according to the schematics.
If it blows, then IC2 will likely die, so removing it (and not replacing it) serves no purpose.
jengineer
47 (100%)
1,169CR
it wasn't removed, it had been de-soldered, the diode was still in place, but definitely no solder on both legs, and no, not 'some bad soldering from an amateur' definitely no solder around both legs, clear as day it was,
weird because the chap I got the monitor off had it working on site, then one day it went faulty, and like I said above came to me with blown fuse and the rest etc
jengineer2016-07-24 18:09:56
5,636CR
That is odd. As far as I know, the chassis can't function without ZD1 in place. Then again, I'm just a mere amateur. Just bits and pieces I've picked up from fixing my own MTC9000 boards...
3,214CR
R81 runs fairly hot anyway but not super hot. Just to rule things out i'd stick a new lopt in for testing for starters. That one looks like an original Eldor so there's every chance it's given up.tb20002016-07-24 19:54:02
MKL
83CR
The zener is used as a voltage regulator (note the grounded anode) together with R29 to get 12v from 24V. The chassis won't work without 12v so that zener is essential.
RSwanson
205CR
It's the same thing. A 12v zener will conduct to GND at voltages over 12v, therefore it prevents more than 12v going to IC2, so whether you want to call it a regulator, 12v limiter or protection mechanism, it doesn't make any difference. R29 is simply acting as current limiting, it's not part of a voltage regulator.
Without the zener, voltage will still make it to IC2, and the chassis won't work you're right, but more specifically the 22ish volts will destroy IC2.
