My first machine!
backflipper
771CR
gazcicini said:
In that case I'll restore externally and leave the insides alone. One last question am I right in saying that as long as I dont poke around the circular item stuck to the body of the screen I should be fairly safe in adjusting the pots I can see on the circuit boards below?
Thanks.
I have been buying the guts of tables that have been gutted by the 60in1 pcb butchers. I should have the bits you will need to restore it.
I think we also might be able to help each other out as I have a taito tavle that is missing the legs and the leg mounts so if we can find a hacked table that has the legs/mounts and cash box we can get both of these up and running.
gazcicini
17CR
I would be very interested in organising something that benefits both and gets machines in a better state. I'll keep asking contacts for another one. I grew up in what used to be a large seaside resort chock full of arcades so these sort of things turn up in peoples (and pubs) basements quite frequently its just the state of them that can be an issue.
gazcicini
17CR
Update on the first project. Machine has cleaned up externally very well, just noticed at some point the glass has been flipped so the space for the "coin entry" label is on the wrong side. It does look like it cleans up well enough to put back as it should be but the decals either side of the screen are not original. Does anyone have digital files for these and the coin slot label so I can send to a printers.
Also the legs have gone off for re-chroming which is good news. Just on the hunt for some original boards now. Does anyone know if there is a list of vertical monitor games out there please. Bombjack for starters as the 60-1 sound is not that great for this and its an all time fav.
Gaz
