Sega CF
AndyGeezer
580CR
Not really, also you need a dimm board with patched firmware and then CF card with an image written correctly using the sector offsets to generate a CRC.
All the info is on the net, but generally it's lot easier for people to go down net boot route.
Fantazia2
2,224CR
I dont think it would be any use.
The DIY Naomi CF card readers are based on a IDE CF card module and that looks like its just wiring direct to the pins on the CF card itself.
Theres a guide over on Arcade Projects for Building one - https://www.arcade-projects.com/threads/the-guided-diy-cf-card-reader-thread.1196/
This thing you have literally looks like its just a CF card extension cable, does the end on the smaller card fit into the CF card slot if you remove the card? Probably its only use would be to provide a remote position to swap CF cards into without having to get access to the Naomi CF Reader.
7,460CR
Cheers fantazia 2 👍
