Hi Guys
i've been busy on this one for a while but only just had chance to knock the first prototype together.
this basically allows you to switch between different Naomi/Chihiro/triforce driving games and re-maps the controls without having to switch pins on the IO all the time, just a simple turn of the rotary switch to any one of the 3 pre-defined pinouts.
This is installed directly to the IO and I have used the same JST RA connectors so the 4 wires that you need to remove from the IO can be reused in the RA input header without having to cut any of the existing wiring, this also allows that whole thing to be reversed should you want to remove it.
Will do a proper write up and refine my design abit,if anyones interested I may also make some to sell on.
Thanks to all that have provided me with pins & connectors etc to get this finished.
Setch
Setch
