Sega Naomi Universal side art info
2,206CR
Now I've got silver decals working nicely I'd like to get the Naomi Universal side art done.
Just not sure what's actually on silver though so would like a bit of clarity on how the original stuff looks.
The 'Naomi Universal Cabinet' is all in foil - are the letters on a clear piece you stick to the side in one go or are they individual letters that stick to the cabinet sides? I can do those with a pre-mask if so, to make them easy to line up and fit.
Then there's a red stripe with text on - is this normal or silvered vinyl with white letters printed on? That's the bit I'm really not too sure of. It's quite tricky to work out how it is in pics I've seen.
The same art is used for both sides of the cab isn't it.
sosfx
74CR
I have a Naomi cab with that foil on the side I’ll have a look and let you know do you photos as well?
sosfx
74CR
So the letters are individual and the red strip is foil with silver words and yes it’s the same on both sides
it could be also that the whole leg is covered in one pice (please see photo) you can see where mine is damaged hope this helps
sosfx2017-10-21 12:11:53
