Sega Rally
Hurray Banana
2,738CR
Smraedis said:
Really nice work on this, some of the turns go really well. Have noticed you change the gear into 4th really late though.
thanks, I had thought that a few times i was topping out in third so maybe need to work on that
Hurray Banana
2,738CR
Just did a little better. 3:21:42 Muerto can you update the tables again please?
Just gotta nail the last bend on desert and the 2 bends out of the tunnel on forest
Smraedis
105CR
Nice work again, well done on that Desert time, it's almost perfect. The forest stage didn't go so well, and it's usually the same for me too, on all those turns.
Hurray Banana
2,738CR
Bettered my time again 3:21:35
Got two webcams setup now so you can see my ugly mug
. Also think I've got me sound settings sorted now.
Mr20to5
1,365CR
Hi pal.
Impressive times aside, it was just as much fun watching your expressions!
Much better hearing the sega sounds as well.
What time are you aiming for?
Neil
Hurray Banana
2,738CR
neil1637 said:
Hi pal.
Neil
Thanks neil,
aiming for sub 3:21 first then see how impossible it looks to get sub 3:20
deano76
91CR
Managed to get a go at this earlier
Had a good crack at it and on the third I managed to clear the Mountain stage !
Took some pics of my times then realised I was using the Lancia instead of the Celica which you guys have been using...
Nevermind I've got a start on it, will have a good few go's with the right car this next week, as you can see I have a long way to go
The ... is me by the way
Maybe's should have been the POO entry instead compared to your lap times
deano762015-03-01 19:52:24
Hurray Banana
2,738CR
It's a start Dean, get some games in to get rid of that poo
My first times were in the 3:28's.
It doesn't matter whether you use the celica or delta but stick to one machine as they handle subtly differently. You'll find it tricky until you get used to changing gears without thinking and you've gotta learn the courses obviously.
Hurray Banana
2,738CR
Had a few goes on my Sega rally after rebuilding the power supply and managed to beat my best time by 2 hundredths of a stir second. Was just a quick go so not streaming unfortunately..
3:21:33
2huwman
365CR
Seriously impressive times HB
I've been practising for a while on my sega rally twin with the goal of breaking the 3.25 barrier (which I finally did):
But watching your playthrough had given me loads of areas where I could improve. So thanks very much! Couple of quesitons - is the consensus that the Celica is faster than the Delta? Seems that way for me.
And what do you reckon is the absolute fastest time possible with a perfect run?
Hurray Banana
2,738CR
Congrats on breaking 3:25. Keep going you will make large improvements
My scoreboard (before my machine died) required sub 3:22:50 to get in the top 16. Haven't had any time to play much lately.
Based on some of the lap times I have got when racing and cocking up a lap or too, some of my best times are
Desert 55:55 - always remember this
Forest sub 1:16
Mountain sub 1:08
Probably around 3:19:50
Assumng you don't use the Lancia Stratos (although that does keep a separate score table).
Great thing about this game is the handling and you can always chase 3 perfect laps.
2huwman
365CR
Thanks - it's good to know what to aim for! Awesome desert time.
I need to put some serious practice in with manual transmission.
I've played it a fair amount on the model 2 emulator version as well, but that seems to run faster and has different positioning of the opponents, so I'm not sure it's really comparable with the arcade.
Hurray Banana
2,738CR
Yeah seen some silly times done on Model 2, and the cars are in easy position it appears by default.
It was like playing monkey ball on the gamecube the timing was fixed to refresh so the timer ran at different speeds in 50Hz and 60Hz modes.
Keep up the playing
Hurray Banana
2,738CR
Just recorded a quick video of Sega Rally for my students (we do a unit on arcade history). Thought I'd have a go at playing automatic while trying to film on my phone didn't do that bad, the filming is rubbish, it's hard trying to play and keep looking through the phone to see where you are waving it.
[tube]KS9u1F9s4Hc[/tube]
2huwman
365CR
Impressive single-handed racing! Some kind of head-mounted wide-angle camera would be useful. I did strap my phone to my head for a mame pc demonstration i did!
I got back to a bit of sega rally the other day after not touching it for a month or so. getting closer to breaking the 3'24 now.
i had a few scrapes on my best MT time, so I'm sure that can go under 3'24. The AT time seemed like a really smooth run, but could probably have been a bit more aggressive with some of the turns.
2huwman
365CR
I finally got into the 3.23s, which means my fastest manual gears time is faster than my best automatic.
Having watched your video more HB, you go down into 2nd gear in lots of places where i only go down into 3rd. I've been worried about losing speed, but I guess you get better traction and a better line.
Also - should I be using the Delta? I switched to the Celica a while back as it seemed slightly faster, but your best times are with the Delta aren't they?
2huwman2016-11-15 08:35:18
Hurray Banana
2,738CR
Well done, you will improve from there for sure.
I can do similar times in both cars. Going into second stops you sliding too much but you need to get back up the gears (don't hang in second)
