setting credit/cost of play
ismailfouad
1CR
Hi,
I just got my C120 coin mech fixed for my boxer arcade machine. excel credit board was set to 50p for 1 play, £1 for 2 plays and £2 for 5 plays. Now i need to change this to be £1 for 1 play, £2 for 2 plays, £3 for 3 plays, etc. I have attached pictures below. I am new to this and just starting out trying to set this up so would be great if you can help. Thanks in advance.Boxer machine.jpgexcel credit board.jpgboxer setup.jpgc120.jpg
ismailfouad
1CR
So to be clear, Swicth 1 is the bank with 5 switches, and Switch 2 is the bank with 6 switches? because other manuals calls that bank switch 3.
qjuk
50 (98%)
1,879CR
Yes, switch bank 1 is the one with the 5 dip switches (“SW1” should be silkscreened on the pcb to left side of the switch block next to dip switch 1). This bank of switches sets the price of play.
The other bank of 6 switches is actually switch bank 3 (“SW3” should also be silkscreened on the pcb to left side of the switch block next to dip switch 1). This bank sets the coin validator type that you have connected to the Excel board. In your case you are using a Money Controls C120, with the coin windows programmed as: 1:£1, 2:50p, 3:20p, 4:10p, 5:n/c, 6:£2.
In which case the SW3 dip switches should be set to: 1+2 on, 3-6 off.
