I recently powdercoated all of the metalwork on my Star Wars because some areas were a little rusty or a little scratched. The powdercoating looks great and most parts are screwed on with coach bolts or button head screws which I also replaced with imperial UNC fixings.
The one part that is more difficult to do is the speaker grille as it is riveted on. For this you can either apply new rivets or use threaded wood inserts with matching button head screws.
I spotted a post on KLOV and I ordered some 3/16" black pop rivets that are the exact same size as the ones Atari used. The seller (Joey Cuda) sells them for $0.25 each is the same guy that supplied the black repro cardboard bezels from my earlier post. Here is the link to the rivets:
http://forums.arcade-museum.com/showthread.php?t=267698
I also got a new pop rivet gun off ebay for £5.
The only recommendation I would have is to put a piece of black electrical tape over the end of the rivet gun hole, pierce it and then insert the rivet so that the black paint stays on the rivet when it breaks the mandrel.
Here are the rivets and my Star Wars after riveting the grille back on. Believe me it does look a lot better than in the photo due to the flash:
