Grandiloquence
Hi all,
Back in June I posted a WTB for a Supergun setup. Thanks to one reply in particular I was inspired to build my own solderless supergun! It has been complete for a while now but I thought I would post this up to hopefully show that it just takes a bit of perspiration and inspiration (thanks, Titchgamer!) to produce a perfectly acceptable result:
It took a couple of weeks all told as I had to order some bits that I missed out. I had some issues with the SCART connector, every standard cable I tried didn't work, luckily I had a high quality Belkin cable which worked fine so I had to use that in the end.
It's currently set up with only 1 controller port because I have no friends. But seriously, I ran out of enthusiasm for cutting the case as I found that to be the hardest and most frustrating part of the build!
I would like to eventually build on into a metal case but that would take some real skill to fabricate so I'll stick with this for now!
