Discs of Tron environmental restoration
91 (99%)
5,283CR
Didn't get to much time today as it's Easter but started stripping bits off it to aid in a deep clean and sort the metal work.
91 (99%)
5,283CR
I've never known something so convuluted and overly complicated. Finally can see all the way through it.
Hope I remember how it goes back together
91 (99%)
5,283CR
Removed the monitor this evening, it went from filthy to clean but I'll go over it once more. I will be using an anti-static brush to clean the yoke.
Monitor chassis will be cleaned under the tap in the sink then sent off to be rebuilt and serviced by @gunblade .
Made a first pass on cleaning the inside also but I can't get right into the machine until the coin door is off.
91 (99%)
5,283CR
Gave the chassis a rinse. I'll give it another clean with water and washing up liquid before sun drying it then sending it off for servicing.
The horizontal width coil plastic gave up and snapped so it will need at least a new one of those.
91 (99%)
5,283CR
I've been fighting these rusted security torx screws for the last three days. I managed to get three out but the other nine just won't come out. I have tried every trick in the book including an extraction kit.
Currently waiting for some special mole grips to arrive from Amazon.
91 (99%)
5,283CR
The mole grips didn't work so ordered a Dremel.
The Dremel arrived at 5pm so I went straight out to the gameroom and got to work.
91 (99%)
5,283CR
Pretty much fully dismantled other than some wiring and the lighting and ballasts. I managed to clean inside all the nooks and crannies with it all apart.
It will be time to start putting it back together soon
91 (99%)
5,283CR
So!
This game when I got it was missing the game PCB, linear power supply brick and power supply PCB. I've temporarily borrowed the power supply out of a Tapper that I have and acquired a rebuilt power supply PCB and a working game PCB.
I've installed the brick into the game and start testing voltages.
91 (99%)
5,283CR
As all fluro tubes were tired and dead. I ordered:
4x F15 T8 cool white (CW)
2x F15 T8 black light (BL)
2x F15 T8 black light blue (BLB)
This may come in handy @u72 , all from eBay or Amazon which I found had the best prices.
91 (99%)
5,283CR
Smelly carpet time 🤢🤢🤢
The carpet was originally purple (and clean!), removing it shows how gross it actually is. I was surprised the ends hidden on the metal clips were purple as I only remember the wine red colour from back in the day.
I've measured it up to get a nice new purple piece cut and installed. I'll need to buy a carpet stapler as it uses these really thin long staples to attach to the wood.
91 (99%)
5,283CR
Small update. Started removing the decal from the metal floor pan and cleaning up the rust.
I've ordered a wire wheel for the drill for a final pass as the small one on the Dremel was taking ages.
Also the replacement sidemirror blades turned up this morning. Many thanks to @Fatsgt for selling them to me.
91 (99%)
5,283CR
Got the surface rust off the floor and the coloured residue from the floor decal.
Ready for a new decal to be applied now 😍😍😍
