Hi folks, my colleague and I have done some work to this board too. Because it's pre-Jamma I ordered this
adapter board from pcbjunkie.net in Canada so I could use it with my
Supergun. We did a repair the broken leg on TPP2-C-4A, this was accomplished by using a Dremel to remove some of the package to reveal some bare wire to solder onto. We then used a short length of thick wire to make a new leg. It doesn't look pretty but checks out continuity-wise as a fix.
The page for the adapter board says the following;
The original Nintendo pcbs output inverted video signals and require an external sound amplifier, while bootlegs output normal video signals and have an on-board sound amp.
And since this is an original board I set the video jumpers to the inverted position. The video output on a Sony Trinitron KV-25 looked like this:
In the video I first rotate the combined RGB pot on the Supergun, followed by the individual RGB channel pots on the adapter board. So from this I can see the game is running, I can insert coins and start the game, and sort of play it. But the picture is kind of terrible. Can anyone suggest what to do next? Could it be that my TV is not capable of displaying the inverted RGB signal? Or maybe there is still something wrong with the board? Any advice would be appreciated.
Thanks in advance!
