Super Hang On mini ride on restoration
Arcad3
19CR
Here's a post about the restoration of my Super Hang-On mini ride on which I did (started 😄) almost 4 years ago (time flies :eek:).
Day one: The pickup!
So far I did only one restoration, which was my Outrun upright cab. This was the first time I had bought a cabinet with rotten wood.
When touching the cabinet the wood instantly felt down. :giggle:
But restoring a broken Outrun gave me trust, this was just another fixable Arcade!
Or not? 😊
Posting to be continued... (very) soon.
Arcad3
19CR
When sitting on the bike and moving to the left and right there was a beeping sound audible...
The base didn't look good either... 🧐
Also there was a very strange pair of (original) wheels mounted, run-flat wheels I guess.
it seems like Sega was way ahead of its time in 1987! :LOL:
Arcad3
19CR
I couldn't wait and started to do some cleaning to get quick and easy results and get to know some more about the current state.
Unfortunately the manual was missing... Probably eaten by someone who has been very hungry... :ROFLMAO::eek:
At least the original tool was still there!
Arcad3
19CR
First I took the frame apart and removed the parts with the big rusty springs on it.
My main goal in a restoration is to ensure that the arcade cabinet survives, rust is my biggest enemy because it eats the arcade machine/parts.
Parts which are often unique and can not be found in a store. So I felt the need to save the springs and their parts as quick as possible.
After taking everyting apart, I started sanding, and sanding, then sanding, and after that sanding.Like in Sanding-Eat-Sleep-Repeat. You know that song? :)
And then it was time for the good feelings: the feeling you are really saving nostalgic arcade parts!
On the left the freshly painted parts, on the right the second spring with it's parts, partly sanded.
Jummy!
One done, one to go!
Arcad3
19CR
O nice!!! I started mine a few years ago! so need to find the time to get it done! I have a post on here LINK :) Are you going to repaint the Bike plastics?
I was going to say “No, because I don’t know the color codes”. Also I do like it when it looks authentic like it is old and has been in an Arcade, but… I quickly scrolled your thread… Didn’t took time to read it for now. But WOW that paint job turned out great! It looks so much better than the faded state most (mine also 😉) is in. The blue seems to match, how did you do that? Tried 20.000 cans of paint, just lucky, or somehow scanned the original paint with a device which can name a RGB or hex code? 🤔😄
bbz149
26 (100%)
1,608CR
O, that's probably pic from another member's machine! I plan to get the Blue scanned for the original color code! Not sure about the White, was it actually bright White from new!
Arcad3
19CR
Ahh yh it is from someone else then..
Scanning would be awesome!
Now I think of it…. It might be found via Honda as it is a replica of the Honda NSR500 😊
Also inside my Super Hang-on folder I see I have saved the following text from somewhere (don't know the source):
For the blue, i found that the RAL5002 ultramarine blue is the closest match.
Seems to be ok, but not an exact match?
Arcad3
19CR
After restoring both springs I continued with the base plates.
The screws were stuck, so I decided to use my Dremel to cut the screws... inside my room, because it was standing in the attic and it was no option for me to go downstairs with it. :oops:
It took quite some time before I got them loose, because I didn't dare to let the shower of sparks fly into my room for too long in case it would set it on fire haha
But that was not the only reason why it took long...
Because I wore glasses, I conveniently did not wear safety glasses... BAD IDEA!
A spark went under my glasses and got into my eye... there was a burning pain in my eye, water didn't help so I went to the hospital.
They were not so happy to see me as it was in covid time and they were very busy and not amused to see someone who acted stupid by not putting safety glasses on. Oops... After they removed a piece of Arcade history out of my eye the pain was gone, I bought the most expensive safety glass I could find, went home and continued the job. In the end I got all screws removed.
Unfortunately it was all rusty, I had to remove the carpet which I did clean earlier because I couldn't wait and wanted to see quick and easy results... cleaned it for nothing. 😊
This was also the goodbye for the original RS Taichi inc. sticker.
I guess the decision of removing the carpet was a good one...
The surface was too big for sanding by hand, so I bought a grinder and that saved me a lot of time!
There were all dents in the plates caused by rust, I didn't took the time to make it all flat. Actually I also don't know what material to use for that purpose on metal.
The most important thing was that I did beat the rust on these parts too.
A picture of the restored parts so far... waiting to be reassembled:
Chopper79
665CR
For the pitted areas, that you want flat, I would recommend dolphin glaze. I'm restoring a 4 foot metal arcade sign, and had the same problem. brilliant stuff.
The motorcycle in the game was based on the Rothmans Honda NSR500 ridden by Shinichi Itoh, who competed in the All-Japan 500cc Championship in the 1980s.
Arcad3
19CR
Thanks, changed the text! Dunno why I wrote Yamaha while posting a picture which said Honda. 😅
Also saved a link to dolphin glaze, sounds awesome, would make it look really nice!
