Might be a dumbass question, but is that transformer just in there for the monitor?
My pfx is 240v so the 110v is spare .Might be a dumbass question, but is that transformer just in there for the monitor?
And I have bolted the audio amp to the iso now it makes a good little shelf for the audio amp and has multi grounds points mounted there also .
... plus, if you get enough information about the PSU itself you may find that there's a good few rails isolated for separate things which might give you cleaner power for each of them.from the 12v & 5v rails on the pc psu
Some of the Naomi use the doughnut transformer for sega audio amp .
some iso transformers like this one have it too .. so I’m using this for audio and 110v for if I need to add a sun psu.
Or 110v chassis in future.
I’m going to next try to run the capcom io & the Naomi sega io from the 12v & 5v rails on the pc psu so I can loose the Jamma psu.
Thanks mate … yeh especially when you see the route I had to takeGreat to see it fired up and working mate
Fair enough mate the fact that you used an 'ancient sack truck I commend you for itThanks mate … yeh especially when you see the route I had to take
With it on an ancient sack truck! 😅
I would have done a 31khz & 15khz side by side comparison if I had another kettle lead at hand .. but that’s for another day 😄
Lol…. I have a access to a modern one with Hydrolic wheels but this old one is tall, Which actually helped with the awkward shape of the Naomi’s Big plastic rear cover. Now for the next one egret or centipede ? Not looking forward to itFair enough mate the fact that you used an 'ancient sack truck I commend you for it![]()
🤣. Maybe one day hey?I always buy SEGA ... no EGRETS, maaaaaaaan
Start them young on it and they will love it
I want them all especially that gorgeous Egret II, very envious as always.
❤️Start them young on it and they will love it
