Sega r-tuned power test
7,220CR
Just wanting to test power is ok
On this race tv cab ….
Will check fuse on this distribution board …
Then unplug all the power outputs
And meter across them out puts and see
What it is
All about 100v I think
739CR
Look at those hands ... can tell this bloke has never had a day's hard graft in his life!!
7,220CR
The two small voltage converters
Are
1. 12v. (. I/o ?
2 .24v. ( ffb motor ? /. Sound amplifier ?
I think the Sanwa pfx is 240 or 100v ?
and the Lindbergh 240v
So could this cab be without 100v?
AndyGeezer
569CR
That is a 100V distribution board, the two yellow wires coming in are from the transformer and should be a 100V at around 6amps
24V for the Audio amp is from a separate PSU and the Lindbergh, JVS get the volts from the Lindy PSU.
7,220CR
Cheers andy
Testing the transformer yellow 2 wires for
100v Am I ok with ground probe & live probe either way round ?
AndyGeezer
569CR
Doesn't matter what way, but you should be reading around 100-110VAC from those two yellow wires, if not then trace to 240V going into the Transformer, very rare transformer goes bad TBH.
5,627CR
AC current flow changes direction 50 times a second (50hz in UK), so it doesn't matter which way round the probes are on the terminals.
