Do you want to get good at the original arcade Pac-Man? The solution is here!
My "Pac-Man Pattern Trainer" plugin for MAME, will help you to improve your Pac-Man playing skills.
It's an interactive aid to learning common patterns for completing all of the boards.
You follow an on-screen path while playing regular Pac-Man and you’re assisted through each board - I suppose you could call it a Pac-Nav.
To master the patterns, you must stay on track, with frame perfect accuracy, anticipating the turns and steering early into the corners.
There are different pattern sets to help you achieve your specific goals. You may want to reach the 9th Key at level 21 - from which point all of the remaining boards play the same. You may want to complete the game by reaching the infamous split-screen at level 256. You may want to achieve a "Perfect Pac-Man" score of 3,333,360 by eating every pellet, every bonus and every ghost possible. You may simply want a new PB!
The trainer is really easy to install and use with MAME. See the project page for full instructions.
Features
- Select from 3 pattern sets (Pacstrats, Killerclown and Perfect_NRC)
- A HUD shows basic information: level number, pattern number and current status (ACE, OK or BAD).
- An interactive guide path. The colour changes from green to red when lagging behind and your status drops from "ACE" to "OK" and finally to "BAD". Following a red path does not guarantee success and you must be cautious.
- The trainer supports partial patterns. For these, you will be guided for a short time before the path ends (or turns yellow). The HUD will display "F/S" (FREESTYLE), and you will be on your own to clear the remaining pellets.
Link to my project page on github:
https://github.com/10yard/pactrainer
See below for an enthusiastic video review by GenXGrownUp.
Features
