Problem Atari mains supply switch
petercasino
205CR
Hi,
I'm trying to replace the mains wire to an Atari cab. The mains cable goes through a hole in the metal plate. Does the plastic thing that holds the wire in the hole come loose or do I need to cut it with a stanley knife?
Thanks
gunblade
23 (100%)
8,909CR
you compress it with pliers and it pulls out, you can see an area on the right which is the latch of a sort - put pliers left to right in that photo, compress and manipulate out
