100v step down transformers
Stox58
25CR
Hi,
I'm looking for a 100v step down transformer to power Candy cabs, I've found this one
https://airlinktransformers.com/product/chassis-mounting-toroidal-transformer-standard-range-cm0750170
Is 7.5 A output enough to run a Candy cab ?
Plus I would prefer one with 250v, 240v, 230v primary's and just a 100v secondary, does anyone know where I can find one ?
Thanks from Luke
penrhos
747CR
I have the airlink 500VA 100V step down and it's perfect for Naomi & other kit that needs 100VAC. I used to have a 1KVA one to run 4 candy cabs in a row
FanDabbyDozy
22 (100%)
170CR
Stox58 said:
Yes a Naomi Stepdown transformer would do the trick, any idea where I can get one from ?
Thanks from Luke
Hi Luke just put up a wanted add, as probably find one local, if you get no Joy I think I have a spare, but heavy to post.
All the best Adam.
JAG555
129CR
Agree! These are great!
obcd
3,830CR
Really see no reason why you would need multiple primary voltages like 220V, 230V and 240V. The input voltage of a cabinet is not that critical. You can feed it anything between 100V AC and 120V AC.
7.5 Amps should be enough for a cabinet. Use a Watt meter to check the consumption of your cabinet to make sure.
