The ones used in sega games aren't a common fitment, IIRR and way
smaller than the standard edision type used in houses etc so it may be
wise to take another look, I would be very surprised if B&Q or any of
the big chains stock anything that will fit, however you can still buy
the part from Suzo.
Regards,
Craig
Andrew Welburn wrote:
> Quoting Ronnie Dent <
netdent@yahoo.com>:
>> Anyone know where i can get these for my Daytonas? they are screw in
>> standard light fitting size, or the size of an everyday house lamp,
>> also need some florecent tubes about a foot long, guess they will
>> be easy enough to find.
>> thanks Ronnie
> Go to B+Q, you can find (edison) screw-in 240v 40W lamps, they will
> work just as good and give you the equivalent luminosity. But beware
> of the different sizes of screw-in threads, take an old one with you
> to compare.
> Light bulbs of different voltages are interchangeable so long a you
> know what power system they were intended for, ie using a 240v 50W
> lamp in a socket that will supply 120v will consume half the wattage
> (25watt) and therefore give you an approximate brightness to the
> previously fitted lamps. YMMV and IANAS. Works for me though.
> Foot long flo tubes, yep very standard.
> Andrew Welburn
