Switching power supplies with multiple voltage outputs like Arcade switchers, PC power supplies and so on often have only the main voltage regulated, the secondary voltage(s) are just tracked to the main voltage. This means, the secondary voltages are not truely regulated, they just follow the regulation of the main voltage. So a low power consumption on a secondary voltage can lead to higher voltages than expected, especially if the main voltage has high load.
If you want to regulate every single voltage, you have to use seperate regulators and seperate transformers for every output voltage or you have to stabilize the output voltage with linear regulators after the switcher. Both solutions will make the power supply much more expensive than the solution with the tracked voltages.
