14 Kortek
Baiterhater
73CR
Ok moved to tech for some advice.
Yes defender outputs separate positive H&V sync.
These monitors are dual voltage so i tapped into the 120v side the other connection is as below
I connected my defender output
H = Horizontal sync
V = Vertical Sync
E= ground
and RGB
I also flicked the little switch over to positive.
All three of the monitors won't sync i cant find a manual to see if what I'm inputting is correct
Cheers in advance
just
Baiterhater2017-04-02 14:45:52
Baiterhater
73CR
Thanks Chad but no way am i cutting my defender cpu about for these little monitors
Ive now got 2 out of 3 going one of them is missing the adjustment board any of you monitor gurus got one hanging around ??
or can i fit 5k pots straight to the chassis in the unpopulated holes ??
Just
Baiterhater2017-04-02 19:50:28
