15" G05 question
4,058CR
[uk-vac] 15" G05 question
Before I get too involved in this, it appears I have a G05-801 HV board in a
G05-805 monitor (v5 or v6 805 deflection pcb by the looks of it).
Is this a workable combination??
I get deflection chatter, heater glow, no spot killer but no HV, no 90v and
the fuse in the HV cage blows.
The cage mounted transistors are good, am just checking the ones inside it.
Martin.
4,058CR
Re: [uk-vac] 15" G05 question
Just to follow this up, from what I can gather reading manuals and such,
this 801 HV cage should NOT be in this 15" 805 monitor!
I believe the 801 HV works 0n 25v (although it claims to be able to work up
to 38v) and the 805 HV works on 40v.
I further believe that the symptoms I am seeing (slow blowing of F900) are
just typical of it working correctly because the extra voltage is causing an
HV outside of the working range and thus the X-Ray protection circuit (well,
the clamp circuit) is kicking in and blowing the fuse to ensure the thing
shuts down.
If anyone knows different can they please let me know.
If this is the case then has anyone got a spare HV cage for an 805, or I
think a 15V2000 HV cage would also work? Doesn't have to be working, but it
does, need to have a known good LOPT (obviously) if that's the right word
for what's in these things!
I may have a spare G05-801 HV cage by the looks of it, but need to test it
in a 19" 801 first to see if it really does work or not. I guess the SCR
(MCR102) could be bad but I don't have another to try.
Martin.
> Martin.
eggwheatis
cheers
65CR
801 HV cage will work fine with 805 deflection Ive
seen it a couple of times in monitors ive fixed.
> monitor!
> shuts down.
> know.
> try.
> Martin.
> the looks of it).
> > Martin.
___________________________________________________________
NEW Yahoo! Cars - sell your car and browse thousands of new and used cars online! http://uk.cars.yahoo.com/
4,058CR
Hmmm, okay, fair enough!
Any idea on why the fuse might be blowing? I've pretty much exhausted the
few lines about it in the B&W Vector FAQ :eek:)
>From what I can see all the transistors are okay and the Zener diodes that
they say to test are okay. Haven't tested that SCR yet (actually an
MCR106-2, not what I said last night!).
Not sure what next...
Martin.
>> monitor!
>> shuts down.
>> know.
>> try.
>> Martin.
>> the looks of it).
>>> Martin.
4,058CR
Well...
Fixed the HV. Measured everything and tested everything and when going back
over things again I discovered that the plastic isolating sleeve had bust on
the TIP31B (EHT transistor) so the emitter was shorting to the cage and
causing the fuse to blow.
Now then, anyone know if I'm meant to be setting this to 12KV (the "optimum"
voltage for an 802/5 HV cage) or to 14KV (the "optimum" voltage for an 801
HV cage)?? In other words, do I set the HV voltage to the spec for the HV
cage or the tube?
I can't get the HV to go below 13KV and the picture shimmers - don't know if
they're related.
Haven't swapped out the deflection board yet which I can as I have a working
spare.
Just over the moon right now that the HV works :eek:)
Martin.
> Martin.
>>> monitor!
>>> shuts down.
>>> know.
>>> try.
>>> Martin.
>>> the looks of it).
>>>> Martin.
