1942 JAMMA adapter
kernow
2CR
Last night I helped a friend make a JAMMA adapter for an old 1942 board, after 3 hours making the thing (my soldering blows arse), I plugged it in and boom .. nothing. I don't know if the board itself is dead, or if my adaptor pinout chart he provided is totally wrong.
Being a custom pinout it has a lot of things on it like coin 2 and all this kind of stuff, plus several things seem to go to pin 28. wow, worst description ever.
I guess the next step is to meter the +5/+12 pins on the actual pcb when connected and seeing if its getting any power at all right? I'm no good with this older stuff.
Strange how the board is dual layer and the bottom layer has the parts side facing downwards also.
I've noticed theres two pinouts for it also on the net. blegh.
favouredson
Super Star
1,260CR
This pinout matches the one in the manual.
Only GND should be connected to pin 28 so, if you have multiple (different) connections there, that may be a problem.
You might want to check there is not a short between GND and +5V on the PCB and that you have everything wired correctly on the adaptor before applying power again.
Not strange at all. There are lots of PCBs designed that way. (Especially Capcom ones.)
The internet is a wonderful place to visit but I wouldn't want to live there.
favouredson2011-01-30 22:15:51
kernow
2CR
hah, thanks, its another ground going to pin 28, I'll have to double check all this tomorrow and have another stab at it, cheers.
karlcdoe
887CR
It might be a bit late now but I always start adapters by wiring up relatively 'safe' connections first. Eg GND, +5v (no +12v or -5v as they're usually for the sound amp) + monitor connections only. If it powers up at that point without going bang then you're most of the way there apart from the killer +12v.
I know there are some exceptions to power supply requirements such as RAM that perhaps requires 'weird' voltages but the above works most of the time for me. You can certainly go a long way to confirming which are the ground and +5v rails, irrespective of what the internet pinouts say by measure from a convenient 74 series logic chip back to the edge connector.
kernow
2CR
I might just desolder a load of the wires then apart from power and video and see how it goes. I know I should have done that to begin with doh.
favouredson
Super Star
1,260CR
It's slightly pointless removing most of the wires only to re-connect them again if they are already correctly wired. It would be simpler to verify the connections first and alter them if necessary. If they are all correct then you'll be wasting time better spent on finding the fault.
kernow
2CR
I guess that is a good point. So I need to check continuity with all the connections I guess. Time to brush up on my multimeter skills.
trm
2,877CR
If you have any trouble with metering out the connections, post a decent photo of your multimeter and we can tell you what to set it to.
Should be pretty easy to fix once you've validated some wiring - do you know if the board is meant to be a worker (or bought as working years ago and sat on a shelf) or is it possibly duff?
kernow
2CR
It was bought working by a friend, but yeah, not sure to be honest, it was a couple of months ago he bought it now, and the guy who sold it didn't have an adapter for it.
But yeah, could be dead, I did a visual inspection and it doesn't seem to have any obvious problems (such as misseated socketed roms or whatever) (about as far as my visual inspection skills go).
trm
2,877CR
I reckon we work on the basis that it's a worker then - optimism never killed anybody :)
Once we've definitely got the loom figured out then there are some simple-ish tests that we can help you through to see if it's porked or not.
cheers
tim
kernow
2CR
Ok I desoldered every wire and started with the basics, power and video. It's working :D
This pinout I've been given is all over the place though, a pin on the opposite side of the jamma connector is +5V lols. I need to definitely look at a proper pinout for this before I continue any further.
Cheers for the help guys.
favouredson
Super Star
1,260CR
kernow said:
......I need to definitely look at a proper pinout for this before I continue any further......
I provided a link to the correct pinout in my first post in this thread...
favouredson2011-01-31 21:38:42
trm
2,877CR
Nice one - job done. This discussion has really made me want to play 1942 now, so I'm going to a) have to find the bugger and b) sods law make up an adaptor for it!
Damn you kernow
hehehe.
kernow
2CR
Yup finished the controls and audio / coin etc and its perfick. The audio seems to buzz if the volume is too high, but if you turn it down a bit its hardly audible. The buzzing that is.
Would that be just because its an old board and the quality of the amplifier hardware, or old audio caps or what? or its just like that? :D
Cheers for all the help geezers, its a bloody hard game too, christ I thought cave stuff was difficult!
trm
2,877CR
The audio could be a mix of things. It could be that the PSU isn't filtering the output DC very well, so the 12V line has some mains hum mixed in, it could be that the electrolytic caps (the can types) are drying out and changing value, so not acting as the designed filter or it could be that it was just a pretty cheap and ropey design in the first place.
How noticable is the hum when the volume pot is set to a normal game-playing level? If it's nasty then there are a few things that we can try, I'd suggest the first one being trying it in a different cab to rule in/out whether the JAMMA PSU is sending grotty unsmoothed power to the board.
Also, ISTR you're a bit of an audio geek - does it sound like mains hum like you'd get if you touched a mic input with your finger? That'd be a pretty strong clue that the fault is poor smoothing caps.
kernow
2CR
Hmm, its hardly noticable when you put the volume to a suitable gaming level. its just a kindof buzzing in the background really, definitely related to the audio though.
great technical description there kern. erm, it's not my board anyway so I'll see what the owner says when he plays it in person, I've described the 'issue' to him via PM so we shall see.
I'll try it in my other Egret II actually also, see if it does it in that. :) Power supplies in them are fine for other games, no buzzing on those.
