1942 pcb audio bug
jizzfu
3CR
I have a 1942 board, it works but the audio is "buggy".
i can hear only half of the sounds, some music when the plane respawn and the effects (fire, engine..) no music in game.
I tried to change 2x ls374 and 8910 audio chip (checked schematics), but same problem. So i decided to change ALL the audio parts (check the pic below, all red marks are che ic changed), but same problem! (2x 374, 2x ls27, ls32, ram 6116, eprom, z80cpu, 2x 8910, ls86, 2xls74, ls367,ls138)
Anyone have ideas? thanks!
7,230CR
Have you probed with a logic probe to see if there are any dead pins , checked traces as well ??
Also have you checked amp and caps ??
Dave.TheDaddy2022-04-26 21:39:31
cliff_poole
1,069CR
Could be the coupling caps CC7 to CC12. They look bent over in the picture so you could have a broken connection.
You could listen in to each of the outputs of the synth chips. Download a copy of the schematics. I'd take a jumper wire from pin 1 of the volume pot and touch it to each of the output pins on the AY-3-8910s in turn.
sukhbir
46 (100%)
1,737CR
As there is two 8910 sound generators I would scope the 3 channels (pins 3,4,38) on both and when you find the 8910 with missing outputs then back track to locate the culprit chip or open or floating signal.
kold666
20 (100%)
174CR
In the past I changed a couple of defective AY8910 with some dead channel ( + one AY8912 on the vectrex with one dead channel)
1942 has no op amp, the AY8910 channels are tied with some resistors all togheter and go to the amplifier.
if you have an audio probe ( just an amp with a flying input wire) I would check that all the AY8910 channels are working.
I bet one AY8910 needs to be replaced
Lurch666
4,519CR
Also remembered one member had a graphic issue with a 1943 PCB.
He checked the graphic eproms and they came up fine but when he replaced them with new eproms the problem went away so even if the sound eprom checks ok it might not work properly in the PCB.
Long shot but worth a try.
favouredson
Super Star
1,260CR
kold666 said:
Did you change the ay8910 as I suggested?
That was mentioned in the first post...
jizzfu said:
......So i decided to change ALL the audio parts (check the pic below, all red marks are the ic changed), but same problem! (2x 374, 2x ls27, ls32, ram 6116, eprom, z80cpu, 2x 8910, ls86, 2xls74, ls367,ls138)......
kold666
20 (100%)
174CR
sorry didn't read you changed also the AY8910. You have changed all the audio parts then. Very strange you still hear only half sounds. The 6 channels are mixed with resistors so nothing more to check.
kold6662022-05-07 23:09:12
cliff_poole
1,069CR
There's still the coupling caps cc7 to cc12. They are in line with each of the channels. If one gets knocked, leg pulled out, or goes open circuit, you'll loose a channel.
