1942 Repair progress
Purity
The Oracle
17 (100%)
2,999CR
Spurred on by Lurch666's recent tech post for 1942 I thought I'd have a look at the one I've had sat on the shelf for while
On powering up of the game I had corrupt graphics:
Had a look at the main Z80 CPU and there was no activity going on. Looked at the clock signal and it was missing.
I traced this back to pin 7 output of H6 which was stuck high. This is a 174 and the input was pulsing so something was wrong here.
Piggybacked a 174 and the game booted, but with lots of issues:
I had previously checked the roms out of circuit and they were all good (rev B).
I also went over the rams and roms with a logic probe and didn't notice anything odd.
I really like Capcoms schematics as they break everything down into sections, so I thought I'd start in the Character generation rom section to see if I could spot anything. Checked the last chip in the chain, a 7611 @ F1, and that was fine, then 157 @F3, and then got to E4 and F4, both 194's. Oddly pins 5 and 6 on E4, and pins 3 on F4 were dead. That was odd because the corresponding pins to the 2764 @ F2 were pulsing. I dug out the multimeter and found there to be no continuity.
I had a look at the back of the board, and found a number of broken traces. God knows what the hell has happened to this board!
I don't know if you can see on the picture but I had multiple breaks all over. It almost looks like someone has intentionally cut the tracks
So I patched up on the broken tracks I could see with some kynar wire and then booted the game.
I was pleased to see the following:
I thought I had this completely fixed but I noticed a gap in the Capcom logo on the second 1942 screen:
Also in-game I notcied that I was getting some random blocks in different locations. I switched to the test mode and everything looked ok, but after going through a few options the blocks appeared there aswell. Every time I selected a different option from the menu, the blocks moved. I assume this is when the screen is redrawn?
Anyone seen anything like this before and have any pointers?
Lurch666
21 (100%)
4,518CR
My first guess would be a memory problem.Unfortunately it's hard to diagnose those.
I end up just replacing likely suspects.
I'm only guessing here but I would look at the scroll ram at A9.Don't even know if this actually holds screen info but if it does it might be the culprit.
As for those damaged traces that's probably due to 1942 being a dual board with the boards being back to back-The solder side of a pcb is full of spikes so if the boards come into contact with each other that sort of damage can occur.
Ace`
PlanB contributor #1
40 (100%)
4,040CR
I should keep better notes, I had that exact issue with the line through the logo. I remember having a bad batch of certain TTL where I had to replace them all on the bottom board, LS86s maybe?.
The blocks looks like a ram problem like Lurch said, 2114s on the bottom board iirc, I had a similar issue with a boot popeye recently.
Purity
The Oracle
17 (100%)
2,999CR
Checked the roms, they all ident ok
I piggybacked the 2114 rams on the bottom board and it did not make a difference
I will have a look around the TTL on the bottom board. It might be quite hard finding this issue :-(
Purity
The Oracle
17 (100%)
2,999CR
I notcied the 2148 ram at J4 was getting incredibly hot very quickly, and the legs on both chips were a bit crusty, so I swaped them both out for 2114-12 rams. The game now seems to not have the random blocks appearing, however I still have the gap in the capcom logo and on the test screen I now have some dotted lines on the hard colour option, and a missing line on one of the planes on the object screen.
I am wondering if the 2114-12 is not fast enough as a replacement to the 2148 ram I removed?
Purity2018-09-15 10:46:26
Purity
The Oracle
17 (100%)
2,999CR
Hmmmm, I don't recall the lines being there before, so it must be the 2114 ram. I'll need to see if I can get some 2148's
Yes, there is still an issue somewhere as there is a line through the capcom logo
biglouie
84CR
I had one of the boards I received recently with similar issues on the back with the traces, I assumed it was where another boards solder side had been pressed hard against it in transit... I had pieces of PCB littering the bottom of these boards when they arrived, so really quite likely given the packaging job! :)
Hope you get it fixed!
Funhouse71
1,084CR
Purity said:
Just to update this. I have seen other repair videos and the line through the Capcom logo is normal
I have an original Capcom 1942 boardset I've just booted up in front of me.
When powered on you get the stretched blank rectangular bar that then shrinks to reveal the CAPCOM logo, no split in the middle then it goes to main game attract for a bit then once that finishes it goes back to 1942 front splash screen where it shows the 3 middle expanding rectangular CAPCOM logos, each time there is no split left after the logo has finished expanding to full width.
Now you're not going completely mad but I had the same corrupt logo and so like yourself I checked out all of the original CAPCOM Mistsubishi roms and some checked out ok and some didn't. Thinking I solved the issue I replaced the ones that didn't match with the corresponding Mame rom set and this still didn't fix the corrupt CAPCOM logo.
In the end I replaced pretty much all the original roms bar one with fresh ones and now logo is fixed. I can only assume the roms light read ok in a programmer but when under strain in the game the rom that contains the logo data is outputting slightly duff graphics data, why it only affects that rom I don't know.
Funhouse712021-04-23 00:01:13
Purity
The Oracle
17 (100%)
2,999CR
Hmmm interesting, thanks for the update. I think I did replace the rom that I thought had the logo in it, but I'm wondering if the problem might be that the timing between the roms is off, rather than the data itself. I'll take another look at it and see if I can improve that line
Apart from that I think the board is fixed
Flinnster
The Dino King
29 (100%)
2,566CR
There was definitely a fixlog somewhere where it was mentioned that Mame doesn't emulate that mirrored logo box correctly - it exploited some feature of the hardware gfx banks on the pcb.
