1942 sprite problem
Lurch666
4,519CR
Just replaced two 2114s on this 1942 original to get the sprites to appear but they still aren't correct:
the sprites appear to be all there but at certain points on the screen alternate lines of the sprites appear behind the sprite.
Poking around now to see which part of the board handles mixing the sprites with the background in the hope that it's where the fault is.
lix
546CR
That could be either one of the 74LS86 XOR gates used for sprite direction flipping, or more likely one of the 74LS163 sprite position counters in the address generator circuit for one of the sprite line buffer rams. That's where I've been poking on those boards with this kind of issue before. Have a look at the OBJ LINE BUFFER page in the 1942 schematics.
Lurch666
4,519CR
You know sometimes when you think "How could I be so stupid".
Well this is one of those times.
Thanks to lix for the great info.
Was able to narrow the fault down and decided to force pin8 of each 2148 (2114 equivalents) that handle each alternate half of the sprites to see which side of the object line buffer was producing the graphic fault.
When I did F2 I got half the aircraft but it moved properly.When I did the same to J4 I also got half the aircraft but it was jumping around.
Soooooo-I figured that the 2148 at J4 was at fault.
My mistake was when I forced pin8 of J4 high I saw the problem but I had disabled that chip so the fault was in the OTHER 2148.Godammit.
So I socketed the 2148 at J4,saw no change and then realised my mistake.
ANOTHER socket fitted to F2 and now the sprites are fine.
Just got no sound but I'll leave that for another day.Could just be a faulty amp or maybe my test jamma connection has failed again(cheap Chinese stuff).
EDIT:looks like it IS my jamma setup.Just wiggled the speaker wire and got sound.Out with the soldering iron again but at least the board is fully working.
Lurch6662018-09-04 12:07:22
Shinydaz
814CR
I have a 1943 kai with similar issues, I'm guessing this will have a very similar setup, will have a poke around later, thanks for the info.
VectorGlow
34 (100%)
900CR
I often find that a common point of sound failure with those Capcom boards which use them are the AY-3-8910 sound chips.
1942 has two of them on the top board.
1943 doesn't use them, instead it has 2 x YM2203 chips - these also tend to fail a lot in my experience.
Naturally sound faults can be caused by all manner of other things in the above instances (sound EPROM, amp, logic chips, RAM, poor socket, corroded or broken track, etc, etc), I'm just pointing out the most common points of failure in my experience.
VectorGlow2018-09-04 15:05:44
Lurch666
4,519CR
LHantz said:
Got one with no sound as well. Will be interested to see your next post on this
Sorry dude can't help.
Turns out it was my test setup-speaker wire came off.Sound is working fine and the board is fixed but hopefully some of the advice Vectorglow gave might help you.
