1943 Board/Sync Issues
Tommybiscuit
59CR
Hi Guys,
I have a 1943 board I salvaged from another cab. When I plug it into my cabinet I have some syncing issues, the image appears to be repeated multiple times. It coins up, sound works, the controls appear all good. I have never had any problems swapping boards in and out until now? Is this a board fault or monitor issue? See attached some photographs
RGP
Meeter & Greeter
2,039CR
I'd probably be taking a stab at the vertical counter circuits. Repetition is usually where one bit gets stuck causing a reset of the drawing circuit so it picks graphics up again from the start.
Is the picture rolling as well as repeating or have you got stable vertical sync - picture is constantly stable but just repeated (hard to tell in the photos).
Tommybiscuit
59CR
Yes stable vertical sync - no rolling - the picture is constantly stable.
I will get some more suitable pictures.
I will do a bit of research on the vertical counter circuits - Thanks
RGP
Meeter & Greeter
2,039CR
Ok, well that tells us something.
Here's the schematics: https://www.arcade-museum.com/manuals-videogames/1/1943.pdf
On page 5 at the lower right you'll see 2 x LS161 chips - these make the vertical circuit, my guess would be that the one at 14L which has the upper bits in has one or more stuck outputs, because there are only 2 chips in this circuit counting up to the vertical resolution, internally the chip will still pulse the CA (carry) so that the V-SYNC signal is still made.
There isn't much more to the graphics circuit as the entire screen is repeating not just one layer so the addressing circuits are being simultaneously corrupted.
That's where i'd start, I could well be wrong.
RGP2017-01-25 17:22:51
RGP
Meeter & Greeter
2,039CR
Sorry, what I should have explained above is that the vertical circuit is a binary counter from 0 to 256.
Ever 1/60th of a second, a pulse is sent into 14J - 14J is a 4 bit counter and starts at 0 and counts in binary until it hits 15 (1111), at which point it gets reset and sends a carry signal to the one at 14L which increments by 1 (0001), next time 14J is full and resets, another carry is sent and 14L increments again (0010) and so on until that eventually outputs 1111 at which point, it (14L) sends a carry signal which causes 14J and 14L to be reset to 0000, because of the way this is all wired up on this circuit, you get a signal for 256 which heads up to the LS138 decoder at 11J which when V256 goes in and other conditions are met, it sends a LO out on pin 12 to an inverted or gate (LS08) at 11H which combines with the horizontal counter (identical circuit just running faster) and makes a familiar negative composite sync signal.
So those chips are sending carry and causing the H and V sync properly but the graphics are repeated because when you get to approximately 85 (for 3 repetitions), something isn't going further (my guess is V64) or if it's only 2 repetitions then V128 which means that 128 is always subtracted from the vertical address although internally the 14L chip is still counting up.
RGP2017-01-25 17:32:33
Tommybiscuit
59CR
RGP - Thanks for your lengthly reply this is an excellent starting point. I will have time over the weekend to look into this.
Whats even better is your website has the molex connectors i need for my SI project - Excellent!
