1978 Midway Space Invaders Fly Back
7CR
Hi all, I recently became the proud owner of an original arcade cab for the first time. My good mate Nintendo Arcade kindly dropped it round to me at the weekend.
I need to source a new fly back. Can anyone point me towards where I an buy one? I know this might not be an easy task and Vic (from 10 pence arcade) said maybe I should de shell a 19 inch CRT and use that.
But I want to try and keep it as original as possible to start with.
Any help or advice gratefully received from this noob.
7CR
Ah, it say's the shop is currently unavailable
GameOn
133CR
He sometimes has none in stock for sale, as he keeps them aside for repairs.
Although are you sure the flyback is dead and it is not the high voltage diode between the fly back and the anode cap? I repaired a 'Dead Flyback' chassis just be replacing that diode (and recapping the thing including the 4 cap can).
GameOn2016-11-15 17:55:09
virtvic
The Cabaret King
21 (96%)
2,012CR
The anode wire has come away from the flyback (I saw this when it was still with Alex)
Also, the mains wires and signal wires have had the molex plug from around them removed, so Mr Retro Hunter will have to get another connector to sort it properly (although he can just shove the pins into the connector, but best to do the job properly)
Retromark
4CR
Hi ally,
I popped into your shop a little while ago and we spoke about my midway space invaders restoration, I remember you talking about your flyback,
The spare one I have is shot.On the fly back you have the anode wire is meant to come off,it's so the high voltage diode can be placed between the flyback and the anode wire,so there maybe nothing wrong with your flyback just may need that high voltage diode,it's about an inch and a half long about the same thickness as the red anode wire and must go in the correct way round , hope this helps and hope to pop in again in near future.
