If you've got a brand new timekeeper then you should be fine just chopping the old one out, adding a socket and installing the new timekeeper - the security code will be eight zeroes. I've done this on two now and it's worked fine: I assume they store the security code as a simple 8 bytes and the uninitialised timekeeper is filled with zeroes.
As for programming it, it doesn't look like you're going to find many battery-backed RAMs in your progger which is why I suggested programming it like a normal 2x8 EPROM and adjusting Vpp to a harmless level. All you should need to write to the timekeeper is what a normal circuit would present - CS active, WR active, latch the data and address onto the data and address pins.
EDIT: Just had a look at the datasheet:
http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00000520.pdf
And it wants a low signal on the normal 2x8 EPROM Vpp (pin 21) to set it to WR mode. If you can adjust your Vpp voltage in the programming software you could set it to 5V, bend pin 21 out of the progger ZIF socket and wire an inverter in for that pin to provide a logic low when the progger software asserts Vpp. Haven't paid much attention to the timing state diagrams though.
As I said though, I've not needed to program any of the timekeepers I've fitted to ABIs and I've just done a third one now as a test for you which also worked fine with zeroes as the security code
cheers
tim
trm2011-08-29 16:23:02
