3 layer taito SI
dgs2001
8CR
Newbie to all this retro collecting and repair so please go easy on me!
I am attempting to resurrect a Space Invaders Colour Cocktail.
The game was working one day and then did not come on the next day.
Boards on the bench I can verify all voltages +5, +12 -5 are present and within tolerance.
The bench P.O.R is working as expected staying high for roughly 2 seconds then dropping low.
poking around with a logic probe I seem to have clocks. Checking the 74161 on the rom board at position 5 and 8 these showed faulty with a logic comparitor so have been socketed and changed.
The address lines on the CPU are not showing any activity so pointers please where should I go next?
CPU pin outs as follows (L=low, H=high, P=Pulse, N=Nothing)
15 = P
22 = P
11 = NEG 4.8V
20 = POS 4.8V
28 = POS 12.2V
2 = GND
RESET PIN 12 = H
INT PIN 14 = L
HOLD PIN 13 = L
READY PIN 23 = H
DBIN PIN 17 = L
SYNC PIN 19 = L
INTE PIN 16 = L
WAIT PIN 24 = L
HLDA PIN 21 = L
WR PIN 18 = H
ADDRESS LINES PIN
25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 1, 40, 37, 38, 39 = NOTHING, DEAD AS A DODO
I'm now struggling as the schematic is very blurred in this area.
Can anybody point me the right way please.
Thanks in Advance.
TheDaddy
14 (93%)
7,230CR
Sounds like work ram, rom or addressing circuit. I would pull cpu roms , verify and clean legs. Could be anything though but where i would be looking next.
Dave.
dgs2001
8CR
Thanks for the pointers.
So Its Update Day !
I had a poke around today and discovered that I seem to have a 'dodgy' clock after all.
long story short Pin 15 of the 75365 at position 10 is now stuck low. (this feeds 1 of the cpu clocks)
traced it back from chip 10 all the way to chip 2 which now has pin 14 floating. This seems to be causing a strange output from chip 3 which shows a pulse on the logic probe but makes no sound.
If the logic probe makes a beep beep beep for all other clocks, i'm thinking this is likely a duff signal?
Anyway I ran out of time, but am going to socket and replace chip 2 and possibly 3.
More updates next week !
dgs2001
8CR
Thanks for the pointers, I think I impressed myself!!!
I have socketed 3 chips on the lower board and also discovered the custom shifter (MB14241) on the sound board had very corroded pins. When removed three of the legs dissapeared, however I think I managed a repair, soldering wire to the stumps and fitting the chip to a machine socket which is now pushed home on the board socket and all pins are showing good continuity to the underside of the board.
Finally getting some where as I have now moved from a dead board set to a board set which generates randon colour blocks and has the watchdog barking, also whilst probing the sound board, I can get my logic probe to generate a saucer noise from one leg of the SN76477
YEAY. Today I take this as a win !!
Now where to next to sort the picture ??
bones
1,628CR
It's probably time to post a couple of pics of what your monitor is actually displaying and perhaps some of the PCBs so we can see the board reference numbers. Being colour does this mean it's a si part 2 ? Only asking because I have a working si part 2 cocktail table and a couple of faulty stacks I'm intending on looking at in the new year. I could do with locating some clear schematics too as I have to agree that the ones I've come across are unreadable in places and some of the TTL chips from memory are incorrectly numbered in regards to how the board is actually laid out and which chips the tracks/traces really go to.
RaveN
1,325CR
Focus with the core of the board.
Do the RAM bar test with the roms removed, which is well documentated in the Midway maintenance/repair manual. It will confirm whether the CPU/Ram/Clock and associated buffers are working correctly.
If there's no bars, check the CPU, are the clocks out of phase and 12v (I dont think testing these with a logic probe powered from 5v is a wise idea)? It's not uncommon to lose one of them, or one of the data/address buffers.
Do you have an oscilliscope?
Are you able to burn the SI testrom?
When the say the address lines are dead, do you mean logic low or floating (high imp)?
The WAIT and READY readings suggest the CPU is waiting for something (so you won't see any activity), and something external is signalling that data is ready on the bus, so the other readings should help narrow down why that is, but I'm not sure without reading the 8080 manual.
Kaizen088
130CR
Recheck the RESET pin on the CPU, if that's still HI then you need to check POWER ON RESET at the edge connector (Pin10) then go to the reset circuit, (2x74161's at 17 and 21 or 2 and 8 depending on which board you have).
If it doesn't go LO when powering the board up you'll have no activity.
I'll dig out my schematics and add a link to this post, they cover the two different sound PCBs as well.
Taito 3-Layer Schematics...
https://drive.google.com/open?id=1hLgPXNC5DSTakjUERnC2zBavF2zbt2bR
Kaizen0882019-12-22 01:00:26
dgs2001
8CR
Thanks All,
Having had a stupid busy festive season, its now back to normal and I should hopefully be able to get this board sorted.
Kaizen, thanks for the steer on the reset circuit. There was something stuck here. Probing the 74161's at 17 and 21 the reset circuit was high, but accidently shorting a couple of pins with the logic probe on chip 21 sets the reset low and fires the CPU into life. I followed this back to chip 6 on board 1 and decided to rebuild the clock circuit.
There have been a couple of chips replaced previously but not socketed, and while replacing chip 6 I found some dodgy traces and lost a couple of pads.
Still all sorted with some jumpers underneath. Not pretty but hey ho.
Getting somewhere now, The CPU is now fully active
on power up.
Alas still no picture or sound, just some blue snow on the screen.
Is there any appetite for a redrawn CPU schematic for the 3 layer Taito board?
I'm thinking I can redraw the schematic in autocad if people can help me check it gets labelled properly?
Thanks & Happy New Year!
Kaizen088
130CR
Good to see you making progress.
I was going to get around to drawing up the schematic ussing EasyEDA so I can do a PCB reproduction but that won't happen within the next 6 months.
Would be good to have some clear schematics though.
dgs2001
8CR
So I made a start at redrawing the Taito Cocktail Space Invaders CPU Schematic today.
Its not finished and there are a lot of labels to correct and add, but so far so good.
Once its finished I will upload a PDF version scaled to A1 but for now here is a jpeg screen grab of where I got to.
It is drawn in autocad with all the chips, invertors etc hand sized so the scale wont be exact and the same component may be drawn at two different sizes due to the layout evolving as I drew it.
Any help with confirmation of missing/red labels would be appreciated.
Feel free to reproduce elsewhere but with a link back here please.
I probably wont get much time to finish this for a week or so, but will update as I can.
