3D printy stuffz
virtvic
The Cabaret King
21 (96%)
2,012CR
Not sure if this should go in this section - if not, Mods please shift it elsewhere...
I got a Wanhao 3D printer from t'lovely wife for my birthday and after modding it a bit to make it better than out of the box mediocrity, I have been busy on it with some pretty good results so far.
No arcade bits just yet, but there will be. Just for fun, rather than actual practicality.
Buttons, joystick balls, pcb feet, maybe even draw up a whole joystick?
I am currently working on making a Raspberry Pi Grrl Zero, like this - https://learn.adafruit.com/pigrrl-zero/overview
I managed to make the top part ok, which is the biggest print I've done so far, but inknown to me at the time, I was using a flexible PLA rather than the usual stiff stuff (Mother in law got the wrong product for my birthday!) But, it was okay as a proof part.
Here are some of the parts I have done so far...
Hurray Banana
2,755CR
that's not too bad 3 hours, one of the guys at work has got one and he always talks about lattice in fills. I think he had some software to do that for him.
He even prototyped a ring for his missus before sending the data to a firm that milled him one. It will be interesting to see what useful plastic breakable parts this can replace.
Nintendo tall buttons Vic?
virtvic
The Cabaret King
21 (96%)
2,012CR
The slicer software (I use Cura) sorts all that out for you. You can make it more or less dense, which obviously effects the strength of the part and also the time to print.
All that's involved is to get a 3D model (.stl normally) Shoving it thru Cura with the settings you want to use and let it produce the g code. Pop that in The printer and let it have it.
The essential part is it starting correctly. As long as the base goes down ok, things normally work ok.
