4-wire coin counter
big10p
Coins detected in pocket!
6,093CR
I've got a 5v, 4-wire meter from a sega cab I want to wire up, but unsure what the wires correspond to. Wires are yellow, black and two white. It's jap wiring so don't want to assume anything based on colour. Not even sure why 4 wires are even needed, TBH! Anyone know what's what?
Cheers.
Flinnster
The Dino King
29 (100%)
2,566CR
OK totally guessing but... for 'modernish' Sega wiring whites are normally ground.
I would say yellow is likely the voltage..12v? And black is probably the meter count / input from the credit board.
big10p
6,093CR
Hmm OK, thanks. I tested the 2 meter pins on the credit board (voltage and signal), and it seems all the signal does is pull the meter voltage to ground briefly. So the 2 whites could kinda of be ground in as much as being 2 signal lines, allowing 2 mechs to uses the same meter, or something. That still leaves an extra wire for something, though.
I have a couple of spare meters so think I'll do a bit of experimenting with one to see if I can work it out. Do the coin counters in dino kings only have 2 wires, then?
qjuk
51 (98%)
2,134CR
No, both the coin meters in a Dino King have 4 wires. One meter is 12V and connected to the Excel credit board, the other meter is 5V and connected to the game pcb.
Of the 4 wires on the coin meter, one pin is connected directly to ground from the PSU, another wire is connected directly to either 12V or 5V, a third wire is connected to the coin counter ground on the Excel board for the 12V meter and to the Coin Counter output from the pcb/Jamma connection for the 5V meter. The fourth meter wire is a ground out going to the credit board (on the Dino King both the 4th wires on the 12V and 5V meters are wired together and go to the Excel board 0V input). This 4th wire is a pass through to provide the ground power to the credit board, so if you disconnect the meter from the circuit it kills the ground to the credit board (I assume as an anti tamper to prevent the meters from being disconnected and therefore the coins not being counted).
big10p
6,093CR
qjuk said:
Ahhh, I see. Thanks a lot!
