5v - GND Short
Setch
The nice ad-min
542CR
Hi
I’ve got a Namco DSP board that appears to have a short between GND & +5v I cant see any broken traces or damage to the board or connector pins, if anyone could shed any light on what failed components could cause such a fault or offer any advise as to where to start looking that would be greatly appreciated.
I suspect the whole board is probably toast now but am interested if anyone has any tips on fault finding this kind of issue.
The only interesting anomaly I can see at the moment is a 74f224 which also has pin 11 tied to the short where none of the other 244’s in series show this but this could just be by design and tied to GND.
I don’t suppose there are schematics available for Super system 22 boards are there ?
Thanks in advance
Andy
philmurr
48 (100%)
2,378CR
Do the easy stuff first and remove anything that's socketed then retry.
EPROM, RAM etc. have more of a tendency to go short than logic IC's
obcd
3,830CR
Connect a current limited power supply to the 5V and GND. Inspect the pcb with an infra red thermometer to see which component heats up due to the current passing trough. That's likely your shorted defective component. Tantalium caps are indeed the first suspects for such issues.
If you don't have an infrared thermometer, you can use the tip of your finger. (You just might end up with a small burn mark.)
Don't set the current 2 high. You don't want the pcb traces to function as fuses and burn trough.
Also check that the short isn't between pcb 5V and case somewhere. A truly short in a component is a rarity. Usually the supply is able to burn up a defective component that consumes 2 much power.
It can be a bad soldering that makes the short as well. When trough hole pins are bent over, they can contact other pcb traces. Normally those are isolated by the solder mask, but that shouldn't be trusted as isolation.
